1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Not quite sure why, it's been sitting for a bit. The master cylinder is a small little thing, is there more to it under the truck? It seems like they are not releasing all the way. Sorry for the dumb questions.
..."some gave all, KIA"...
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Brakes could be dragging due to rust on the drums from sitting. Run it up and down a quiet street a few times appling the brakes often and see if it frees up the more you drive. If you have one wheel grabbing (pulling) it could have an oil seal leaking causing that wheel to grab due to oil soaked shoes. Mike B  | | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Thank you mike (late), I seemed to have missed your reply.
