3 members (55shaker, 50Chevy3100, Perro), 88 guests, and 3 robots.
Topics128,129
Posts1,056,695
Members48,452
#846910 04/26/2012 10:20 PM
We have the old girl sort of up and running. We have to prime the carburetor to get it and then it runs fine once it's going. Once it is warmed up it will start without being primed about half the time, the other half we are priming it. We want to send it out to my father inlaw for the summer so he can drive it, but we aren't comfortable doing so unless it starts properly. Any help or suggestions are welcome.
http://i712.photobucket.com/albums/...9669_723554668_11360660_1950953570_n.jpg
http://i712.photobucket.com/albums/ww126/gustoffur/1956%20Chevy%20Truck/IMG_0308.jpg
1956 Chevrolet Apache 1300
More pix on Photobucket
Trent Lalonde
Saskatoon Saskatchewan Canada
Have you tried the choke?
R-Bo
1966 GMC 305V6 in the family
Riding in the Passing Lane
Nice truck. The accelerator pump in the carb is probably bad. Those carbs are real simple to work on. If the pump is not working get a kit & give it a minor o-haul. If you are not comforable doing it yourself find an old time mechanic to do it.
1972 Chevy c10 Cheyenne Super
Gorgeous truck by the way. Congrats to your father inlaw. smile
Professional Novice
You're the second person to suggest the accelerator pump so that's probably the problem. I am very comfortable putting a kit in it, but is there an accelerator pump in a rebuild kit? aren't most of them just gaskets and a needle valve?
Thank you for all the complements on the truck. It has come a long way in the past 10 years. When we started it had a tree growing through the box and today it is winning awards. My father in-law has carpal tunnel syndrome in his wrist from writing cheques for this truck but he is very proud of it also, so I guess it was worth the effort.
Trent Lalonde
Carburetion specialist
The accelerator pump MAY be an issue, it may not be. They are very easy to test:
http://www.thecarburetorshop.com/Troubleshooting.htm
Replacing an accelerator pump that isn't bad is not going to solve your issue.
Jon.
The Carburetor Shop
The accelerator pump was bad, the carburetor was filthy and there was a ball valve jammed so far back into the plug that it wouldn't come out and had to be replaced. The springs were also worn out. I purchased a used carburetor for $20 and used those springs and the plug for the power valve. Now you just touch the starter and it fires right up. it's amazing how good that old truck runs.
Once again, thank you gentleman for all your help. Now we have to tune, tweek and adjust everything so a 78 year old man can drive this truck everyday like he did 56 years ago.
Trent Lalonde
