5 members (WICruiser, Hotrod Lincoln, moparguy, Barney1951, Peggy M), 54 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#84676 10/24/2007 7:41 AM
I searched but couldn't find the answer. Why do some trucks not have an oil filter? Mine doesn't. Its a 53 3100. Since it doesn't have a filter, do I need to change the oil more often?
Any special considerations?
Thanks in advance. grin
Us girls like them ol trucks too!
New Pics of my 53 Chevy:
Side: http://tinyurl.com/3xtgfa
Dash: http://tinyurl.com/2npafu
Front: http://tinyurl.com/3dhlkv
Savage
#84677 10/24/2007 8:20 AM
oil filters were an option back then, and when included were a bypass system that would clean the oil and dump it back into the dirty oilpan. Changing the oil more frequently is a good idea.
#84678 10/24/2007 3:16 PM
Probably because non-detergent straight grade oil was more common in earlier years, which doesn't need an oil filter.
Detergent oil needs an oil filter, as particles stay suspended in the oil.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#84679 10/24/2007 4:51 PM
I would add a canister filter.
~Jim
#84680 10/24/2007 5:30 PM
I read that I should be using a single grade oil. Not multi-grade? What grade is best? Also, how do I add a canister filter?
Thanks for the answers, everyone. grin
Savage
#84681 10/24/2007 5:44 PM
Because of the lack of zinc in oil after 2006, get Shell Rotella T SAE30 diesel oil or use any regular SAE30 together with one red bottle of STP additive (zinc) per oil change.
If you do a little search, there are many threads on this forum with links to pictures and instructions how to add a remote filter.
1952 Truck - 235
1948 Coupe - 261
#84682 10/24/2007 6:05 PM
Before you add a bypass filter, with it's limitations, you might want to ask yourself "why wasn't there a filter already on the truck?"
I noted on my 56-235 clean engine of unknown mileage, that removing the bypass filter and plugging the 2 ports improved both my idle and cruising oil pressure by 5-7 psi. Recognizing that the bypass filter dumps filtered oil back into a pan full of unfiltered oil, seemed counter-productive when I was more concerned about lubricating my bearings.
If your current engine has decent oil pressure it my have no adverse effect. However, if the PO had removed it to salvage an extra few pounds of oil pressure you might be going the wrong way.
Modern oils, changed at regular intervals (2-3K miles) seems to me, to be more prudent. If you pull the valve cover and your engine isn't full of sludge, I'd feel safe running a good quality straight 30 weight detergent oil that met API certification requirements for medium duty gas engines. If it were sludged up, I would hesitate to run detergent oil without some kind of filtration. Non-detergent would keep her running until it was time for a rebuild. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#84683 10/24/2007 8:38 PM
Ah, thank you. So much to learn. But I'm willing!
Off to search the boards. grin
Savage
#84684 10/25/2007 3:50 AM
If it dose'nt have ZINK then add it. Modern oils offer NO! LET ME REPETE NO!!! protection on flat surfaces. Did I say NO protection.
#84685 10/25/2007 5:37 AM
Actually, the modern oil was reformulated but many of the companies are now providing an oil for older engines with the zddp put back in at it's historic levels. Only difference is they are offering the same formulas they offered 10 years ago but they jacked the price because it is now a "speacial vehicle" oil.
