1 members (Otto Skorzeny), 85 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#846627 04/26/2012 1:02 AM
Sorry I should of read more be for posting.I guess my real question should be, Is there an advantage one over the other between the rochester carbs and the carter.
Not really. The rochesters can be warped and not seal right, and the Carter w-1 tends to percolate on a hot day after shut down a little more. Either on works just fine, if they are clean, and put together like the shop manual says.
I tend to like the w 1 a little more, cause I think they look cool! I've never run a YF.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
The first Rochester B carburetors were prone to leaking and warped covers as mentioned. The 52 and up Rochester B had a cover that was a little higher and was not as prone to leaking as the first design.
Carburetion specialist
C Online: Content
Opinion, others will differ.
Carter W-1 (see link for discussion on these carbs):
http://www.thecarburetorshop.com/CarterChevroletW1.htm
The 1941~1948 models are some of my favorite carburetors.
Carter YF: As designed, an excellent carburetor. Major issues include (A) local FLAPS repair kits have wrong parts for Chevrolet YFs and (B) the neopreme (diaphragm) accelerator pump will have issues with ethanol-laced fuel on vehicles which are rarely driven.
Rochester B: ALL of them will warp and leak through the power valve, although the later design may last a little longer than the early. I personally had a 1959 Chevrolet Biscayne with 9,000 miles which my Dad bought for me in 1962 which got 12 1/2 miles per gallon because of this carb (later design - three years and major warpage). Yes, they can be straightened (and last another couple of years), but I have better things to do than straighten carb castings. Our shop will NOT rebuild these carburetors. If one likes the carb, the neopreme accelerator pumps in the FLAPS kits don't last over a couple of years, but leather accelerator pumps do come in the better kits. We have been trying to GIVE AWAY these units for years:
http://www.thecarburetorshop.com/Free_carbs.htm
Jon.
The Carburetor Shop
