9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible),
189
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84661 10/23/2007 10:42 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Question,
I have searched this but not come up with a lot on it, What did a stock 1952 3600 come with as far as rear gears, I have the 4 spd transmission on the floor.
Birge | | |
#84663 10/24/2007 3:10 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Thanks Randy, How would I decifer the RPO, or in other words how would I see which I have 4.57:1 or 5.14:1 RPO. I suppose this could be done by spinning the rear wheels while watching the drive shaft and counting, I will also look for the tag on the diff.
Thanks Birge | | |
#84664 10/24/2007 7:10 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Keep one wheel on the ground. Lift the other (with a jack). If you can't sping the tire, either your differential is broken or you have a no slip (locker) in the rear. If you spin it 4.57/2 (or approximately 2.25) times, for a single revolution of the drive shaft then you have a 4.57 rear.
You most likely have the 4.57. It's common.
I don't know of any place that has the casting numbers linked to the gear sets. | | |
#84665 10/24/2007 10:03 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Thanks jhaa,
Once I get it back togehter I will do just that.
Thanks Again Birge | | |
#84666 10/25/2007 1:02 AM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Birge, There are a couple other ways to tell the ratio, (which is the ratio of ring gear teeth to pinion gear teeth). 1) You can count the number of teeth on each gear (i.e. 41 Ring gear teeth & 10 Pinion gear teeth =41/10 or 4.10 ratio) or 2) The number of teeth should be stamped on the end of the pinion gear shaft, which is visible from the inside of the differential-you may need to reach in and clean off the end. You'll see a bunch of numbers but some will read something like "GM-7-32" which would mean 32 ring gear teeth/7 pinion gear teeth =4.57 ratio. This method is easier. | | |
