| | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 14 New Guy | | New Guy Joined: May 2010 Posts: 14 | Does anyone know if radiators are available anywhere for a 64 c50? Or know of a radiator from something else that you might have installed in one? I haven't had any luck finding anything yet. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy audey, there are at least three different rads in the parts book depending on the engine and whether you want a standard or heavy duty rad. I can provide p/ns if they would help. The easiest thing to do may be to find an original rad from a wreck, and have that recored, hope that helps. | | | | | Joined: May 2010 Posts: 14 New Guy | | New Guy Joined: May 2010 Posts: 14 | Thanks 3B. I guess my only option will be to recore. The truck I have has a radiator with the number 3000263. I assume it is the original. I took it to get cleaned and rodded out, but they say it needs a new core. $450 to $600. | | |
