1 members (Cletus1950),
77
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 | I have read somewhere that you can make a 90 ohm fuel gauge work with the 30 ohm sender units. Anyone have any idea?
Blah, blah, blah, blah . . . and I really mean that.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy boogerdave, I'm not expert on resistors, it always gave me a headache in school. I believe the gauge (90 ohm) works on a zero to 90 ohm range, so if you put a 48 ohm resistor in the circuit the best you could hope for would be a range of 48 ohms to 90 ohms, so the gauge would never function correctly. I'm sure someone with more expert knowledge will be along to confirm or poopoo my statement. | | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 | Thanks . . I changed the post because what I had been reading was actually 90 ohm sender with a 30 ohm gauge . . . bassackwards.
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Universal 30 ohm sending units are available. You won't have to jump through hoops to make your gauge work right.
