8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I am wondering if there was a headliner in a TF Suburban, or if the roofwas just bare. If there was a headliner, how was it mounted, between the roof reinforcements or under? How was it attached? Thanks
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes, there was a headliner. Tucked under the bows, bows not removeable as you know. The side sheet metal covered the ends. I believe they were bonded. I did a tip on TF Suburban Headliner Idea here.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Nice idea of yours, thanks. If I get it right, your idea ends up looking more or less like the original, right? Shame this does not leave any space for some insulation, or something to limit drumming...
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It looks good but not "original". Never gets cold here, don't need insulation. Didn't have drumming. Big Block Dual Exhaust though! Glad you checked out and liked the idea. Not all my ideas are good. There are lots of good ideas here for original, insulated liners. Search and find. Cheers.
