9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 65 | Quick question, I replaced two exhaust and intake manifold on my 42 chevy 1.5 ton due to a broken exhaust manifold. they are used manfifolds, mount right up no problem. the carter w1 mounts right up without and issue, but i went to replace my carb insulator, and the manifold i just installed on the truck has a metal retaining ring that the insulator would surround. the problem is, the insulator block isnt fitting on it, its just a tad too small at the inside diameter. the bolt holes on the insulator match the manifold bolts fine, is this metal ring important? or can i rip it out? every website i have view shows the insulator block only and no ring. did i buy the wrong insulator? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think the ring was used as a governor on some trucks.
