1 members (baldeagle), 109 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#846276 04/24/2012 4:31 PM
Good morning!
I'm looking for some ways to repair that encapsulated nut that holds the tailgate hinge on a 46' Chevy. The nuts are stripped and need to be replaced.
Can you knock the nut out and weld in a new one, or are there other ways to solve this problem. I'm also thinking that maybe the circle can be knocked out. Are any of these replacement nuts available? Thank you.
I don't know your era truck but are you referring to some sort of cage nut or is it actually welded in place? If its welded I think that would be the answer, even if were JB welded it wouldn't matter once the bolt is attached.
Give me ambiguity
or give me something else
When I redid my '40, I was able to reach up far enuf with vice grips to hold a nylon locknut in place and tighten the bolts down. You can also get a threaded insert ( kinda like a giant pop rivet ) that would do the trick.
1940 Chevy KC 1/2-Ton
