| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Good morning! I'm looking for some ways to repair that encapsulated nut that holds the tailgate hinge on a 46' Chevy. The nuts are stripped and need to be replaced. Can you knock the nut out and weld in a new one, or are there other ways to solve this problem. I'm also thinking that maybe the circle can be knocked out. Are any of these replacement nuts available? Thank you. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I don't know your era truck but are you referring to some sort of cage nut or is it actually welded in place? If its welded I think that would be the answer, even if were JB welded it wouldn't matter once the bolt is attached.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | When I redid my '40, I was able to reach up far enuf with vice grips to hold a nylon locknut in place and tighten the bolts down. You can also get a threaded insert ( kinda like a giant pop rivet ) that would do the trick. | | |
