1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#846054 04/23/2012 7:48 PM
Anyone got a picture of where the throttle cable attaches to a Rochester on the 216?
I can see where the housing gets clamped but I can't tell where the cable actually attaches. ...should be pretty dang obvious too.
Ex Hall Monitor
Ex Hall Monitor
Hmm... I'll have to look again. Clamp or no clamp, I didn't notice the extension at the linkage. I'll have to check again tonight as there were beverages involved last time. grin
[edit]
This is a pic of my old vs. new carb. Doesn't look like it attaches like the W1 you posted.
http://i27.photobucket.com/albums/c...0Truck/2011-11-22163702.jpg?t=1322060081
No it doesn't. The cable goes through the hole in the rod that looks like a cotter pin hole. The clamp then attaches to the cable.
Yep. I found the same answer while you were posting.
http://vcca.org/forum/ubbthreads.php/topics/180454/39_Master_Deluxe_Throttle_Cabl
Quote
The throttle cable is mounted exactly the same for either a Carter or Rochester carburetor. They both use the same Y shapped holder that it fastened under a bowl cover screw on top of the carb. One end holds the choke cable (horizontal) and the other the throttle cable (verticle). The holder clamps around the outter part of the cable. Then the wire extends downwards and runs through the hole in the throttle rod whch keeps the rod attached to the lever on the car. (you probably have a cotter pin in there now)....Then you need a throttle stop fastened to the wire just below the lever. This will pull up the lever when the hand throttle is pulled out.
Thanks guys!
While the Classic Parts Throttle Stop is dirt cheap, you can save yourself some time and shipping cost by purchasing one at any lawn mower dealer.
Drew
Good call DrewP! That's exactly what I was planning on doing. Also, its been suggested to take a pair of needle nose pliers and put a small bend/hook in the extra line after the stop just in case, so you never lose the stop if it comes loose.
Here is a pic of my carter set up
...pic...
I just recently added the cable clamp.
Another members pic
...pic...
I'm glad I saw this....I had the same problem....I was looking for some sort of additional linkage....simple enough to route the throttle cable through the end of the throttle pushrod
Yep. I've looked at it a million times and never woulda thunk.
Ex Hall Monitor
Ex Hall Monitor
Looks like a keeper pin hole doesn't it. smile
Where did you find the metal piece that snaps on to the throttle linkage? I have everything else but that piece and have not been able to find one. Thanks.
Yep.
The small clip that holds the rod in place? Not sure, didn't find one doing a quick search a few suppliers. ...I've had a lot of luck finding these little odd parts at ACE Hardware. This seems like a pretty standard piece for any type of linkage.
try your local auto parts that have DORMAN supplies
Rock Auto
...click...
Im not sure if that Dorman kit 41016 has the correct part but might be worth a try.
I got one from a rebuild kit I purchased from carbking.
Hey, me too. Now I can hook mine up so I can unhook it when I pull the engine. This week I hope. Thanks a bunch.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Thanks, that's exactly what I was looking for.
