1 members (RLB), 119 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#846181 04/24/2012 3:32 AM
I thought I'd put a link to photos of my restoration. There are two links, before and during. Driveline consists of a 261, 3 speed, Dana 60 rear w/3.54 gear ratio.
Before https://plus.google.com/u/0/photos/105513075216719775909/albums/5734683661397246433
During https://plus.google.com/u/0/photos/105513075216719775909/albums/5734701105228276385
Nice photos, thanks for sharing. Looks like you had a nice solid truck to start with. What did the Dana 60 come out of?
Steve
'49 3800
'52 3600
'57 3100
Now that's the way to do things. Good work, shows real attention to detail. Keep the pics coming. Looks like you've been hiding around here for quite a while now. Jump in and answer a few questions some of these neophytes ask.
~Jim
Well done. Your photo gallery is great. I will also ask whats the dana 60 out of? I may go that way as the 4:11 rear is becoming too hard to find. Good detail on the photos.
Thanks for the encouragement! The photos are just dumped in there. I hope to organize them as time allows.
The Dana 60 is from a 67-72 Ford F-250 (3/4 ton). It's not a direct bolt in but is fairly easy to modify and install.
The Ford shock mounts and spring pads had to be removed for the GM pieces to be welded in place. Custom made parking brake cables were made with original GM on one end and Ford on the other. The wheel mount to wheel mount surface is 7/8" wider than the original Eaton. This will make the wheels set out 7/16" further on each side. In the Before photos, there were 1/2" spacers (stacked washers) behind each rear wheel only. As you can see, it is hard to detect even a full inch increase in width. Also, the Dana 60 bearing hubs/axle flanges had to be machined down to accept the GM wheel. Doing this requires the use of "Allen Head" axle bolts. You can forego this step if you use Ford or aftermarket wheels. The Ford "8 lug" lug stud spacing is the same as original and in my case, I was able to use the original lug nuts.
Nice Job Red. Looking good.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
