2 members (Maybellene, klhansen), 91 guests, and 2 robots.
Topics128,034
Posts1,055,544
Members48,425
#846111 04/23/2012 11:22 PM
My emergency brake pedal on my 54GMC won't stay down when I step on it? this was from one day to another. My brakes work fine otherwise. The release works fine too. Any ideas??
54GCPGMC #846118 04/23/2012 11:40 PM
I had that happen on my '51, turns out there is an adjustment that affects the release. The problem is the release is not catching. I think I just adjusted the parking brake...
Kurt
So by adjusting the rear brakes it allowed the pedal to bite?
54GCPGMC #846143 04/24/2012 1:30 AM
There is a spring under the pedal lock that sometimes breaks. It fits around the lock bar.See pic.
My Blog
54GCPGMC #846144 04/24/2012 1:31 AM
Not by adjusting the rear brakes, by adjusting the parking brake assembly.
Kurt
Is that spring available? or is there something else i can use?
54GCPGMC #846180 04/24/2012 3:30 AM
Here is a link to the adjustment of the parking brake foot pedal and parking brake. Don't exactly know why this worked to fix the pedal lock problem, but it did.
Parking brake adjustment.
Kurt
Jim Carter part #MEB114 here is a link to the catalog. jim carter
Tim
1951 3100 Chevrolet
Only off by one number Tim, it's MEB115
My Blog
thanks to all. I just went out to the truck and the spring is there and intact from what i see. I did notice that if i push the release all the way in towards the firewall the pedal bites. If i let go the pedal will come shooting back up. does that help anyone in figuring this out?
54GCPGMC #846237 04/24/2012 12:56 PM
I think that's what mine was doing. After I adjusted everything per the manual. It started working again.
Kurt
I have in the past bent the pedal lock a little to get more bite.
If any oil gets on the shaft it will not catch, you might try cleaning it.
My Blog
i cleaned the oil off shaft and bent the lock and works like a charm now. thanks Dave
