1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | When I got my '51 suburban in 1973, the original engine had a bad rod, so I tossed the 216 and put in a 235. I've been happy with the 235, but I always sort of regreted tossing that 216 engine. About 20 years ago, a friend of mine pulled the 216 out of his '51 Chevy truck and gave it to me, --after it had been sitting in a basement for a couple of years--
I have always thought I would redo this engine, and get everything back original. But now, I'm too in love with the 235.
So I'm thinking of junking the 216. The block has a crack in it, which was repaired with JB weld. So I'm thinking the block has no value. But what about the rest of the parts? Would the crank, cam, lifters, head, dizzy etc,etc, have much value to anyone these days?
I could take it all apart and part it out, but I'd only do it to save the stuff if these parts are still useful.
Thoughts?
Kurt
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Depending on where the crack is, the block might be repairable. The other parts- - - -definitely salvage as many as possible! I've been collecting 216's and both types of 235's for quite a while, and there's always something somebody needs, from a connecting rod or two, a few pushrods, sheet metal, or any number of bits and pieces of hardware that are unique to those engines. I hate to see anything go to scrap! Jerry
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Jerry,
The way the PO repaired the block (crack into the waterjacket) was to form a strap over the block, drill a series of holes, tap the holes, and then bolt the strap to the block in a bed of JB weld. Evidently worked just fine, but ugly as sin. I'll post a pic when I get a chance.
OK, you have just about convinced me to take it all apart and throw it into the parts bin until someone has a need...
Kurt | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The block makes its own best warehouse, if you've got room for it. Just keep the rods and caps bolted together if you decide to do a complete teardown. Jerry
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Yes, Kurt, keep it all together, if possible. Less work for you, and probably more value when you find a buyer!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | A crack in the block, especially in the water jacket can be succesfully repaired and virtually invisable. Keep it and fix it would be my advice.
Cast iron cracks are usaully repaired by starting a little past the start of the crack. First a hole is drilled and tapped. A tapered set screw is inserted and tightened to the pointn of twisting off. The screw is ground down flush with the block. Next, moving along the crack, another hole is drilled and tapped. But, the hole is overlapped slightly onto the previous hole. Again ground down flush with block. This process is repeated until just past the end of the crack. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Maybe I'll try to get the patch off and see what it is covering.
Kurt | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I drive with a 52 216 in my 48. It runs good - no smoke. I like it.
People say the babbits are probably tired. I don't know
I like my 216
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Now, here's another perspective.
I love seeing patches like that. People these days are so worried about making repairs undetectable. I like imagining the guy back in the day thinking "There, I fixed it, let's go haul stuff!!". | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | oldbluetruck, I'm with you. My '52 216 runs well and clean and I picked up a complete spare w/3spd trans for parts a while back.
...when it finally dies tho, I'm already bothering Jerry about a 235. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Here's a little trick to hide the "sewing" job, which is what the overlapping-plug repair is called. Use a portable sandblaster to rough up the block surface a little, clean thoroughly with a scrub brush and some high-pressure hot water and let everything dry well. Then spread a thin coat of Bondo over the repair, let it cure about halfway, and press a piece of 40-grit sandpaper onto the filler. The roughness of the sandpaper is a very good duplicate of the natural appearance of the cast iron surface of an engine block. That's a trick we learned on the round track circuit when modifying Chevy high compression cylinder heads to run in the "claimer" class by reshaping the ID tabs on the ends of the heads. Jerry
