4 members (Hotrod Lincoln, 52Carl, TUTS 59, papas52), 119 guests, and 2 robots.
Topics128,162
Posts1,056,932
Members48,458
Hello, I am trying to figure out what newer model suburban/yukon/avalanche/GM truck I could use to place my 57 suburban body on. Does anyone have any experience doing something like this?
Brandon
Jack of all trades and a Master of None!
http://www.e-zchassisswaps.com/ this is what I am doing with my 1957 Suburban.
My57Suburban
This is the slickest swap I have seen for trucks
EZChassisSwap.com
U
U Offline
Just an FYI on the E-Zchassiswaps kit. Its a great kit, but the rear cab mounts and rear bed mounts are not bolt on. The rear cab mounts of the burb are in a different location than the trucks.
I have my burb sitting on the ez front mounts and the rears temporarily in place so I can pull the frame again and permantly attach the rear mounts.
Good luck.
My Burb is a 1955 2nd BTW.
1969 Camaro SS #s Matching
1955 Suburban Carryall (Cummins powered in the works)
2002 Camaro SS LE#1320
2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed smile
Unclebucks06, you are correct! I forgot to mention that issue, but still better then trying to make that stuff on your own imho. Uncle, do you have any pics of your truck mocked up? I am almost to the point of buying the kit.... Just need to sell 1 of my projects to cover the kit.
My57Suburban
EZChassisSwap.com
