1 members (CATMAN),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,935 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 22 New Guy | | New Guy Joined: Mar 2005 Posts: 22 | I would like to hear from some of you that have done the disk brake swap on the front of your AD I have a 52 3100.
First did you go with power assist under the floor? I have read on some of the kits where it says you may have to do some mods to crossmember (stock 235 and 3 speed).
I want to keep peddle under floor.
If you did the disk bake swap and did not use power assist and only changed to the duel resevor are you ok with it now?
Do you wish you had used the power assist?
Doug
Doug
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | not "may have to make mods to stock cross memeber", you have to mock up a complete replacement, i just did this to my 51 3100. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I want to do the same mod. Are there any write ups on the procedure? Does anyone sell a suitable cross member? | | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | "CPP" (Classic performance products, I think) in Anaheim, CA has a bracket for under floor installation of your brakes. Check them out. | | | | | Joined: Mar 2005 Posts: 22 New Guy | | New Guy Joined: Mar 2005 Posts: 22 | well I ordered everthing for up front disc brakes yesterday. I am staying with the 6 lugs and will be going with manual brakes. Figured I will go with that and see how it does for now. Got the kit comming from Obsolete along with M/C, its bracket and tapered roller bearing kit. I was thinking about doing a tech tips while doing this swap. I'll see how things go. I have a motorcycle trip comming up early May so I'll start on brakes after that.
Doug
| | | | | Joined: Mar 2006 Posts: 18 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 18 | I have a 55.1 AD to which we added an Independant Front Suspension kit from Chasis Engineering. (Great product, everything fits beautifully!)The transmission crossmember came from them also. My underfloor mastercylinder/power booster system came from Chevs of the 40s (part no. EC505.) There was an interference issue with the crossmember which required that it be modified. At the interfenence point we cut about a half inch valley out and then welded in another piece for strength. I'm not a welder so my body guy did it for me. Quick and inexpensive, everything lines up great! (We're using a 327, however...) | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have a few pics in this Folder you can look at. 1950, manual master cylinder. Its a P.O.L. kit. Most kits do not come with very good instructions. I installed all new brake lines also. | | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | I'm most of the way through installing the CPP disc brake upgrade on a 1950 1300 (Cdn) 1/2 ton, and I plan on installing the dual master cylinder (manual brake version) over the weekend.
Things have gone pretty smoothly - I've got a few pages on my blog summarizing what I've been up to.
Main thing is my 16" wheels won't clear the callipers, so I'm looking at replacements.
