| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 30 | Hey everyone,
I know that the hood and fenders on the big bolts are different than the 1/2 ton trucks, but are the grills the same. I am talking about the 47-53 chevy grill style.
------------------------- 1950 Chevrolet 3100 5 window Original 216ci and SM420 4-speed
| | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | The grill in the 1/2-3/4-1ton trucks are all the same. The 1.5 ton & up grills are taller & the grill bars themselves are about an inch taller then in the smaller trucks. You can use the larger grill bars to build a grill but you need the side & middle braces from a smaller trucks to do so.
An elephant is a mouse built to government specifications.
| | | | | Joined: Aug 2011 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 30 | Thank you for the responce
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You will have to modify the side tabs on number one grill bar(top)or it will smile at you.I would hold out for half ton grille bars.The 1.5 ton up the grille bars are also taller or thicker,just don't look right in a 1/2ton.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2011 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 30 | Thanks Guys. I ended up buying a 1953 shortbox parts truck this week so I have most the stuff I need and more. And the grill is good.
