| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84558 10/22/2007 4:53 AM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | I am attempting to remove the crankshaft out of my 41' 235. The last thing I have to remove is the I believe the harmony something or other. It is the pully that is attached to the crankshaft and runs the accesories. In the manaul they have something called the harmony puller and driver. Was wondering where to get this or if i could use something else.
Also my dad Allis Chalmers Model A is acting up. Something with the timing. If anyone has worked on the older Allis Chalmers it has magneto please let me know or a good place to find info.
Thanks | | |
#84559 10/22/2007 5:22 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Delux, The item you are referring to is the harmonic balancer, or crank pulley. This should have two tapped holes in the face and is usually pulled with a common gear puller. A rental yard should be able to set you up with a universal puller that would do the trick. Tell them what you intend to use it for. I have enclosed a link that might help out with the AC mag problem. Good luck. http://www.yesterdaystractors.com/ Stuart | | |
#84560 10/22/2007 8:28 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Stuart is right. Don,t use a puller that grabs the outside of the balancer with jaws. It will ruin the balancer. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
