5 members (porsche, Bill Hanlon, Steelonsteel, ‘37ChevyPU, carbking), 99 guests, and 1 robot.
Topics128,051
Posts1,055,767
I am attempting to remove the crankshaft out of my 41' 235. The last thing I have to remove is the I believe the harmony something or other. It is the pully that is attached to the crankshaft and runs the accesories. In the manaul they have something called the harmony puller and driver. Was wondering where to get this or if i could use something else.
Also my dad Allis Chalmers Model A is acting up. Something with the timing. If anyone has worked on the older Allis Chalmers it has magneto please let me know or a good place to find info.
Delux,
The item you are referring to is the harmonic balancer, or crank pulley. This should have two tapped holes in the face and is usually pulled with a common gear puller.
A rental yard should be able to set you up with a universal puller that would do the trick. Tell them what you intend to use it for.
I have enclosed a link that might help out with the AC mag problem. Good luck.
http://www.yesterdaystractors.com/
Stuart
Riding in the Passing Lane
Stuart is right. Don,t use a puller that grabs the outside of the balancer with jaws. It will ruin the balancer.
1972 Chevy c10 Cheyenne Super
