6 members (Woodcmiami, Gdads51, cmayna, mick53, MickeyP, 1 invisible), 42 guests, and 9 robots.
Topics128,012
Posts1,055,312
Members48,419
#845558 04/22/2012 12:53 AM
Hey everyone,
I know that the hood and fenders on the big bolts are different than the 1/2 ton trucks, but are the grills the same. I am talking about the 47-53 chevy grill style.
1950 Chevrolet 3100 5 window
Original 216ci and SM420 4-speed
8
8 Offline
The grill in the 1/2-3/4-1ton trucks are all the same. The 1.5 ton & up grills are taller & the grill bars themselves are about an inch taller then in the smaller trucks. You can use the larger grill bars to build a grill but you need the side & middle braces from a smaller trucks to do so.
An elephant is a mouse built to government specifications.
Thank you for the responce
You will have to modify the side tabs on number one grill bar(top)or it will smile at you.I would hold out for half ton grille bars.The 1.5 ton up the grille bars are also taller or thicker,just don't look right in a 1/2ton.
Tim
1951 3100 Chevrolet
Thanks Guys. I ended up buying a 1953 shortbox parts truck this week so I have most the stuff I need and more. And the grill is good.
