0 members (),
177
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys I have been trying to find the lift that holds up the rear clamshell on a 49 suburban. Does anyone have a book that tells part number or know if they were used on any other Chevy to hold up trunk, etc? Thanks for any help. Sid
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I believe that they are pretty common items. I seem to recall that early Corvettes used them on the hoods. hood support for Corvette It doesn't look like the brackets are right though. Kind of pricey too. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | these are the same as those posted by K10 only with a lower price. http://mooreindhardware.thomasnet.c...opic-props/telescopic-props/104710-5874?I have ordered them and paid near $10 each + shipping. only differences are the brackets( would have to be changed/modified) and they are a little thicker but work exactly the same. good luck | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys Thanks for the information. I will talk with Moore to see how close they are to originals
| | | | | Joined: Dec 2008 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 35 | Did the hinges elhippie mention work? | | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | I am interested in a pair as well but they have a few models. Anyone know the lenght of a stock one when extended and collapsed?
Thx | | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | So did it work? Any body have any pics of the brackets? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | They are not the same as the corvette supports. I will compare these lifts with the ones I have. If they are being made that is good for us, otherwise I have been working on getting them made too. .............g | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I wouldn't think Moore would know if they are the same as 49 Burb. The link given has a drawing with all the dimensions. Can't tell if Hippy ordered them and modified them and they work or just now ordered them. Sounds like Gmo is comparing that drawing to actual lifts. Those two guys will find the answer. Good work.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | I did order the supports.. They were correct length as the og lifts, opened and lock the same same distance as originals. the difference being they were thicker than the og lifts and the brackets were not the same. (I was gonna make new brackets to match og brackets)
Unfortunately I have since sold them off along with extra parts I had so I couldn't take or post pics | | |
