0 members (), 247 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#845260 04/20/2012 3:14 PM
Question. Will a 47-53 brake pedal work with on a 1954. The reason I'm asking is because my trucks brakes suddenly got soft then returned to normal and I started to recheck the brakes. I checked them a few months ago and they were good then but who knows. Brakes are good but then I notice where the brake pedal (the part you push) is attached to the actuator with BAILING WIRE! The metal on the pedal where the bolt goes that attaches the pedal to the actuator had broken off and istead of replacing the pedal, the PO bailing wired it together. Apparently the bailing wire finally started to give way and the pedal doesn't transfer the foot pressure to the actuator anymore. I never noticed it before because it's right up against the firewall. Anyway, will an older model brake pedal work or do I need to keep my eyes open for a 54 pedal? Thanks!
New_Ton #845277 04/20/2012 5:05 PM
New_Ton
These links should answer your question...
0.832
ILLUSTRATION
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Thanks! From what I gather from this is that the pedal was the same from 47-54. Much obliged!
