| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Question. Will a 47-53 brake pedal work with on a 1954. The reason I'm asking is because my trucks brakes suddenly got soft then returned to normal and I started to recheck the brakes. I checked them a few months ago and they were good then but who knows. Brakes are good but then I notice where the brake pedal (the part you push) is attached to the actuator with BAILING WIRE! The metal on the pedal where the bolt goes that attaches the pedal to the actuator had broken off and istead of replacing the pedal, the PO bailing wired it together. Apparently the bailing wire finally started to give way and the pedal doesn't transfer the foot pressure to the actuator anymore. I never noticed it before because it's right up against the firewall. Anyway, will an older model brake pedal work or do I need to keep my eyes open for a 54 pedal? Thanks! | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | New_Ton These links should answer your question... 0.832 ILLUSTRATION
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Thanks! From what I gather from this is that the pedal was the same from 47-54. Much obliged! | | |
