Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Oswald, cmayna, thekid1950, carbking, baldeagle, TooMany2count), 56 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#845244 04/20/2012 2:26 PM
Hello
Purchased a 59 Apache. (Parts truck} has a 6 cylinder, 235? (Pic in Photobucket under signature heading Past bought and sold projects} Question is, will the starter an
stomp peddle bolt into my 55 which has a 66
283 and original 4 speed? Any and all input will be helpful! Thanks
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
Stranger #845246 04/20/2012 2:33 PM
V8 trucks didn't use the stomp starter.
Stranger #845251 04/20/2012 2:44 PM
It's possible to fabricate a pseudo-stomper by using a push button switch and a home-made pedal, but it wouldn't be original for a V8 truck to have a foot starter. Some people do that when installing a 230/250/292 engine in place of an earlier 6 cylinder engine.
This is further proving my 55 was pieced togather! AS I have figured out, the cab (by door plate) is 58-59, and has hole for stomp peddle. Fender emblems,3200 are long box and it is definatly a short box frame. V-8 emblems may or may not have beed added. There for the confusion, about the starter peddle set up. Did not know about starter peddle - V-8 not going together. Thanks for input!
Stranger
Frank in Iowa
"Mater's Cousin"
Stranger #845261 04/20/2012 3:16 PM
all the TF cabs had the floor hole, if it was a V8 truck there was a small metal plug installed in it .... factory V8 trucks would also have the engine mount brackets riveted to the front cross member
