| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Hello Purchased a 59 Apache. (Parts truck} has a 6 cylinder, 235? (Pic in Photobucket under signature heading Past bought and sold projects} Question is, will the starter an stomp peddle bolt into my 55 which has a 66 283 and original 4 speed? Any and all input will be helpful! Thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | V8 trucks didn't use the stomp starter. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | It's possible to fabricate a pseudo-stomper by using a push button switch and a home-made pedal, but it wouldn't be original for a V8 truck to have a foot starter. Some people do that when installing a 230/250/292 engine in place of an earlier 6 cylinder engine. Jerry
| | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | This is further proving my 55 was pieced togather! AS I have figured out, the cab (by door plate) is 58-59, and has hole for stomp peddle. Fender emblems,3200 are long box and it is definatly a short box frame. V-8 emblems may or may not have beed added. There for the confusion, about the starter peddle set up. Did not know about starter peddle - V-8 not going together. Thanks for input! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all the TF cabs had the floor hole, if it was a V8 truck there was a small metal plug installed in it .... factory V8 trucks would also have the engine mount brackets riveted to the front cross member
Bill | | |
