| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84518 10/19/2007 11:56 AM | Joined: May 2005 Posts: 12 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 12 | I have a 58 235 that I was preparing to replace the valve seals with the head on the engine in the truck.I was removing the rockers and as I was loosening the bolts that hold them to the head I had coolant coming out of the bolt hole that was second from the rear.Is this a blind hole or do I have a cracked head? Any help would be appreciated. | | |
#84519 10/20/2007 12:15 AM | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I've heard of this before, but not sure why it occurs. Someone over on Inliners just used good thread sealant and everything is fine now.
Drew
#84520 10/21/2007 7:31 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Some of the bolts bored in the head go through to water, I wouldn't worry about it.
