7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59), 82 guests, and 3 robots.
Topics128,031
Posts1,055,435
Members48,422
#84518 10/19/2007 11:56 AM
I have a 58 235 that I was preparing to replace the valve seals with the head on the engine in the truck.I was removing the rockers and as I was loosening the bolts that hold them to the head I had coolant coming out of the bolt hole that was second from the rear.Is this a blind hole or do I have a cracked head? Any help would be appreciated.
#84519 10/20/2007 12:15 AM
I've heard of this before, but not sure why it occurs. Someone over on Inliners just used good thread sealant and everything is fine now.
Drew
#84520 10/21/2007 7:31 AM
Some of the bolts bored in the head go through to water, I wouldn't worry about it.
Paint & Body Shop moderator
