Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#845175 04/20/2012 4:19 AM
Some help with an engine serial number would be appreciated. Engine is 235 in 1959 3200.
Engine number F509B 60426 A1
Flint, May 9, ??? or year ???
Donf #845179 04/20/2012 4:26 AM
It may help to your response if you post the casting number as well.
5wests #845214 04/20/2012 11:32 AM
F = Flint
5 = May
09 = 9th
B = Powerglide-equipped car engine
The code above will not tell you the exact year. You will need the block/head casting codes and date codes to ID the year.
Any clue as to what the A1 at the end of the serial # is? Engine appears to be original truck engine with solids.
Donf #845475 04/21/2012 5:19 PM
A1? Maybe someone else knows or can give a good guess?
What characteristics does the engine have to indicate that it is the original truck engine?
You must have taken out a lifter to confirm that it is mechanical?
What is the block date-casting code and what is the block casting code?
You could have a later block that was a factory replacement, or you could have an engine out of another vehicle (used as a replacement)?
The engine ID could have been "doctored" over the years.
