0 members (),
137
0
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Are there any spacers between the steering column and dash on a 53 half ton? I have to draw the steering column up what seems too much to mate the bracket and column to the dash. The Shop Manual just says "install the instrument panel grommet, bracket and spacers, if any" I have the rubber that goes around the column in the bracket but I'm not sure what the instrument panel grommet is? Do I need spacers and a grommet? | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I have taken several of these apart & have found that some have washers shimming then away from the dash & others don't. So I guess if you need to shim it it won't hurt. As for the rubber, I'll there is is the one that goes insde of the two brakets that wrap around the column. I don't think I would have any rubber between the brakets & where they mount to the dash as you want this as secured & tight as possible in my opinion. Hope this helps. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is what I found on my 50, ...pic... ...square nut... ...pic... Small shim between the clamp, washers between clamp and dash. You do not want too many threads going through the dash. Too long a bolt will interfere with gauge housing | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My '52 was/is just like the pictures above. Two thick washers each side. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The thick washers allow for column shift rod clearance to the dash. If you have a floor shift you only need enough clearance for the steering column while maintaining column alignment with the steering box.
Drew
| | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Thanks much....makes sense to allow room for the column shift. I do have the floor shift four speed but will put in some washers to better align the column with the steering box. I'm headed to the boneyard next Wednesday and will add thick washers to my shopping list. | | |
