6 members (Uncles51, spanky, texas46, Hotrod Lincoln, Southerntruck, Steelonsteel), 69 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#845037 04/19/2012 10:15 PM
what engines came stock in a 4400?
rebuid kits?
Power rating?
looked on here little, didn't find it.
thanx
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
thanks.it's a load master so i'm thinking 235.
normally i don't care what it is originally, but my customer want's to use as much original as possible to keep cost down. although i did convince him to let me swap out the rear axle.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
darenhg72 #847277 04/28/2012 10:11 AM
A 4400 would have had a 161" wheelbase. If its got loadmaster emblems etc, then it may be a 235. All loadmasters had the 235.
Of course at some stage someone may have put loadmaster emblems or hood on it.
But it may have had a 216 as these were still classed as 1.5 ton.
You could identify the engine via numbers and castings, and see if it matches original numbers.
There is all the info on oldcarmanualproject.com.
'47 Canadian RHD 1.5 ton truck
yep checked the #'s. it's a 235 that purrs real nice.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
