5 members (Gdads51, dt235sd, FAST55, Nick in Manitou, Bill Hanlon), 87 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
#844517 04/17/2012 9:46 PM
I'm working on my 3/4 ton 53 GMC got the frame sand blasted and tommorow it's getting painted.I'm looking for the rear spring bushings that go on the rear top pins its two bushings that fit unto the top of the shackle. I found the pins and bushing sets for the front and lower part of the rear spring but can't find the bushings for the top part of the rear shackle. The pins are the same but the bushings are smaller in dia. and are two pcs. anybody find some?
Thanks, Pete
check the filling station in oregon. they had brand new rear spring shackles for my 53 chev 3/4ton.
1963 c10
No luck at the filling station,I just need the bushings and don't want to buy the shackle.
I did find the parts I need at Rockauto anyone use them before?
They have the bushings and pins and the king pins for the truck.
Thanks, Pete
I've ordered numerous times from Rockauto and never had any issues with them except for getting the wrong O2 sensor one time but they quickly made it right.
Thanks will order tommorow,Thanks Pete
