8 members (Charles in CA, Nick in Manitou, 51sub, TUTS 59, Bill Hanlon, 1955 1 Series, NJC, WICruiser),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84484 10/18/2007 2:49 PM | Joined: Jul 2007 Posts: 6 Junior Member | | Junior Member Joined: Jul 2007 Posts: 6 | Just got my 1950 235 3600 running. Has everything under the hood for tune up new and has brand new carb. Started and runs like a dream. Took her out on the road ran like a million $. Then out of the blue it started cutting out and like starving for fuel{has new fuel pump also}. Checked all wires, fuel filter, timing advance, fuel pressure, points etc etc. Anybody have any ideas. Thanks guys. :hammering: | | |
#84485 10/18/2007 3:16 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Don Rabold,
If it is a fuel problem, I think the first place to look would be the tank. If it hasn't been cleaned, or has a softened outlet hose on it, it might be restricting fuel to the pump.
Make sure the tank has some means to vent...it needs air as the fuel level drops.
Stuart | | |
#84486 10/18/2007 10:47 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | These old trucks usually have tiny rust particles in the tank. It,s a good idea to put a inline fuel filter between the tank & the pump. Blow out the fuel lines & check any filters in the pump or carb. Then see if it runs ok. You may have to take the top off the carb. & clean out the bowl. If this inline filter gets clogged up in short time you will have to pull the tank & clean it. If it is rusty inside they can be coated but if a new one is available it is better to replace it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84487 10/22/2007 6:47 PM | Joined: Sep 2007 Posts: 9 New Guy | | New Guy Joined: Sep 2007 Posts: 9 | Disconnect fuel line behind fuel pump and attach a plastic 1 gallon container of gas to the line. Attach the contain to the fire wall. Run truck a short distance to see if it cuts out or stalls. If not, you have a line or tank problem | | |
#84488 10/22/2007 10:25 PM | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Check your distributor, I have seen a few times when it turns slightly because it is not tight enough, once it is far enough out of time it will die out.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
