8 members (Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, klhansen, JoergK., 1 invisible), 110 guests, and 1 robot.
Topics128,195
Posts1,057,373
Members48,469
#844638 04/18/2012 5:03 AM
I have a 52 216 that has been rebuilt with dual carbs and split fentons. I'm going to put a 5 speed behind it so I can use it for cruising. What would be a good rear end gear. 2:96 or 3:08? I've been told that the 216 doesn't like running at the higher RPM's Is there anything else I should be aware of as far as driving.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
6T2Burb #844641 04/18/2012 5:35 AM
H Online: Content
Better stay with something in the high 3's or low 4's if you're planning to use an overdrive 5 speed. A 216 won't have enough torque to run 5th. gear with either of the ratios you've mentioned, and I doubt if it will even pull right in 4th. gear direct drive. With the dual carbs, you'll be lucky to make it run at all unless it's revved up. With the oil clearance adjusted properly, a Babbit-rod engine will handle 2500-3000 RPM without a problem.
3:90 or 4:11. If your going to drive in areas that have lots of steep grades you may want to rethink your choices.
I would love to have a five speed with my 216, but, I agree with above comments. A stock 4:11 is perfect, but maybe a 3:55, 3:70 etc. would still give you some pull, and more economy. Forget the 3:08!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
