| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | I have a 52 216 that has been rebuilt with dual carbs and split fentons. I'm going to put a 5 speed behind it so I can use it for cruising. What would be a good rear end gear. 2:96 or 3:08? I've been told that the 216 doesn't like running at the higher RPM's Is there anything else I should be aware of as far as driving.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
| | | | | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | Better stay with something in the high 3's or low 4's if you're planning to use an overdrive 5 speed. A 216 won't have enough torque to run 5th. gear with either of the ratios you've mentioned, and I doubt if it will even pull right in 4th. gear direct drive. With the dual carbs, you'll be lucky to make it run at all unless it's revved up. With the oil clearance adjusted properly, a Babbit-rod engine will handle 2500-3000 RPM without a problem. Jerry
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | 3:90 or 4:11. If your going to drive in areas that have lots of steep grades you may want to rethink your choices. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I would love to have a five speed with my 216, but, I agree with above comments. A stock 4:11 is perfect, but maybe a 3:55, 3:70 etc. would still give you some pull, and more economy. Forget the 3:08!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
