5 members (Otto Skorzeny, greenie-reddy, Hush, Hotrod Lincoln, 1 invisible), 175 guests, and 2 robots.
Topics128,108
Posts1,056,227
Members48,436
Guys I have been trying to find the lift that holds up the rear clamshell on a 49 suburban. Does anyone have a book that tells part number or know if they were used on any other Chevy to hold up trunk, etc? Thanks for any help.
Sid
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
k10 Offline
I believe that they are pretty common items. I seem to recall that early Corvettes used them on the hoods.
hood support for Corvette
It doesn't look like the brackets are right though. Kind of pricey too.
It may be part number 3808753 in Group 17.202 SUPPORT-SPRING-BUMPER, End Gate
these are the same as those posted by K10 only with a lower price.
http://mooreindhardware.thomasnet.c...opic-props/telescopic-props/104710-5874?
I have ordered them and paid near $10 each + shipping.
only differences are the brackets( would have to be changed/modified) and they are a little thicker but work exactly the same.
good luck
Guys Thanks for the information. I will talk with Moore to see how close they are to originals
Did the hinges elhippie mention
work?
I am interested in a pair as well but they have a few models. Anyone know the lenght of a stock one when extended and collapsed?
Thx
Y
Y Offline
So did it work? Any body have any pics of the brackets?
They are not the same as the corvette supports. I will compare these lifts with the ones I have. If they are being made that is good for us, otherwise I have been working on getting them made too. .............g
Sir Searchalot
Sir Searchalot
I wouldn't think Moore would know if they are the same as 49 Burb. The link given has a drawing with all the dimensions. Can't tell if Hippy ordered them and modified them and they work or just now ordered them. Sounds like Gmo is comparing that drawing to actual lifts. Those two guys will find the answer. Good work.
I did order the supports..
They were correct length as the og lifts, opened and lock the same same distance as originals.
the difference being they were thicker than the og lifts and the brackets were not the same. (I was gonna make new brackets to match og brackets)
Unfortunately I have since sold them off along with extra parts I had so I couldn't take or post pics
