2 members (TexasA&M48Truck, Nick in Manitou), 124 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#844204 04/16/2012 1:13 PM
Hi so I have a 1953 1/2 ton suburban, with a 1956 235. I have a 57 car rear that has 3.36.
Can I use the t5 if i dont go into 4th or 5th with overdrive?
( I guess im thinking it seems logical that I could use all 5 gears with the o.d. off, or go up to like third with the od on, if Im on a back country road and wanna save on gas?
Would this wok?
drew_vigil #844207 04/16/2012 1:24 PM
You should be able to find a different center section with some 3:70 or 4:11 gears without much trouble. A T5 with a 3:36 and a 235 would make for a not so fun driving experience, especially in your area with the grades you have to pull.
so i haven't bout the wheels for the 57 passenger rear yet, should I just find like a 57 truck rear for like 100 instead of dropping 200 for two wheels? Lol I thought the gears would be great but I really want overdrive
drew_vigil #844215 04/16/2012 1:56 PM
That would give you a 3:90 ratio. That paired with a T5 would make a nice combination.
A 1955-62 1/2 ton center section will bolt into your 1953 axle housing. You will need to change the mounts to solid spring pads.
My Blog
drew_vigil #844241 04/16/2012 4:18 PM
Would this wok?
You do know on the T5 5th gear is the overdrive and you can not turn it on or off
1938 Gmc 1/2 ton
TheShoer #844252 04/16/2012 5:00 PM
I'm running the t5 with 3.55 with 255/60 rears and love it. Easy 65 on the freeway in 5th and 4th in town often.
40 Chevy 1/2 ton
DennisM #844400 04/17/2012 4:14 AM
So I got the 57 1/2 ton rear end today. would it be eaiser to swap the entire rear end, or just the third member?
"A 1955-62 1/2 ton center section will bolt into your 1953 axle housing. You will need to change the mounts to solid spring pads".----ok how would I do this? Do I need a kit like lmc has?
so the t5 is just a 5 speed not a 10 speed?
drew_vigil #844434 04/17/2012 11:46 AM
It's a 5 speed, 5th gear is Overdrive
Tommy
59 apache 1/2t
261 short stepside
Tommy #844438 04/17/2012 12:38 PM
I'd just change the center section. You will need to weld the spring pads so they are locked in place.
You might just want to put the t5 in ad see how you like the gearing. The t5 came with different overdrive ratios so you need to keep that in mind too.
40 Chevy 1/2 ton
DennisM #844605 04/18/2012 3:27 AM
He will still have to change out the rear end to get rid of the torque tube.
