0 members (),
83
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 7 New Guy | | New Guy Joined: Feb 2012 Posts: 7 | So today I'm heading out to get my disc brake conversion for my 65. And along the way I'm going to stop and pick up a 400 small block I picked up but now my question is what all am I gonna have to do I should just need to switch out the motor mounts any help would be awesome.Hopefully I won't have to many more questions, and be posting some pictures of a finished product | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | We need to know what engine is in it now. I beleive you are going to have a lot more questions. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2012 Posts: 7 New Guy | | New Guy Joined: Feb 2012 Posts: 7 | Sorry I knew I forgot something its the original 230. | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | That stock 230 radiator probably won't do the job very well for a 400. You may have to mod the throttle linkage. If you're sticking with the stock tranny, you may need a different flywheel/pressure plate. You're gonna need a bigger fuel tank....lol. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Or you can get the throttle assembly off a v8 truck and swap it out. Only 2 bolts. | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Going from a 230 I am betting you will also need a set of V8 engine perches too. It won't be a simple slap her in deal, it will take some swapping of parts. It's not that hard, you just need all the proper stuff to go with it.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | 230 eng perches will work quite fine, just move to the rear holes. the 230 b/housing, flywheel and clutch will all work. believe that there is a difference though in balancing; whether the flywheel is internal or external balanced to the 400 sbc eng ?? ron
it is the 292 i6 eng perch that is different on the right side
| | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I did a similar swap in my 1964. It had an original thrift master six with a 3 speed. I put a 350 from a 1975 in its place. I know the 3 speed will bolt right up to it without moving it at all. I also used the same clutch assembly (I was not worried about racing). I can't remember but if I recall my 350 was from a manual truck so it's existing flywheel worked. I used the motor mounts from a 66 V8 that was in a boneyard. You will have to do some exhaust work one way or the other. I just ran a new dual exhaust. I tried running the original radiator but didn't trust the cooling capacity so before summer came on full I updated to a V8 radiator. Depending on the motor that you are putting in you will have to modify some of the electrical. Mine had an HEI so that was part of the process. Also, if you have power steering/brakes you will have to account for it as well. That sounds like a lot and it is. But it went pretty fast and I liked the swap. | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | 400 c.i is internally balanced as far as I know. They need a counterweighted flywheel (or flexplate) for proper engine balance. Take the crank from your 400 and find a cheap 350 4 bolt block. You won't run into issues with cylinder heads etc., will end up with 383 ci for just a little more machine shop costs. If you're replacing pistons etc., your parts bill will be less by going with a 4 inch bore. Just my opinion. | | |
