| | | Forums66 Topics128,127 Posts1,056,675 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 13 New Guy | | New Guy Joined: Aug 2006 Posts: 13 | My 59 Chevy has a terrible driveline vibration. The truck was recently upgraded from 2wd to 4wd. The mechanic put in a new transmission, t-case, front and rear axle, custom driveshafts and 5 inch lift leaves.
The vibration is bad enough to cause the rear axle to jump and hop and I can't even get moving.
I suspect the engine mounts are bad and allowing the engine to twist and move. The clutch might need to be replaced also.
does this sound like a possible culprit. Can I buy stronger motor mounts (something that can deal with the stronger 350 motor). Is there anything else I should look at as a possible culprit.
59 Fleetside Longbed-350 Crate 76 Jeep J20 Ambulance 2007 Wrangler X
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Don is right on, especially if the truck has been raised. Sounds like U-joints are binding. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
