0 members (), 90 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
My 59 Chevy has a terrible driveline vibration. The truck was recently upgraded from 2wd to 4wd. The mechanic put in a new transmission, t-case, front and rear axle, custom driveshafts and 5 inch lift leaves.
The vibration is bad enough to cause the rear axle to jump and hop and I can't even get moving.
I suspect the engine mounts are bad and allowing the engine to twist and move. The clutch might need to be replaced also.
does this sound like a possible culprit. Can I buy stronger motor mounts (something that can deal with the stronger 350 motor). Is there anything else I should look at as a possible culprit.
59 Fleetside Longbed-350 Crate
76 Jeep J20 Ambulance
2007 Wrangler X
pinion angle
Don is right on, especially if the truck has been raised. Sounds like U-joints are binding. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
