10 members (Drew54, Otto Skorzeny, klhansen, 46 Texaco, Stovebolt48, tclederman, J Lucas, Maybellene, 2-Ton, 1 invisible),
106
Mod | | | Forums66 Topics128,281 Posts1,058,488 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84431 10/16/2007 11:47 PM | Joined: Sep 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 46 | I have a 60 Apache and need a slightly longer water pump shaft to line up accessory pulleys. Did they make a water pump with a longer shaft in earlier years? Thanks | | |
#84432 10/17/2007 2:23 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | The long shaft pump started in 55 and went till 62 and to my knowledge are all the same unless their was a special application for big trucks. If you have a double pulley balancer the groove nearest the block should line up with a standard pump pulley and generator. If these do not line up you may to make sure the balancer is all the way on the crank and you have the correct pulleys for the pump and generator. | | |
#84433 10/17/2007 2:40 AM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | If you got the original 1960 235 water pump, it's as long as they ever got...
My original fan pulley of my 1962 261 had two additional pulleys, but they were added behind the main one. I had to cut them off and shorten the shaft to fit into the 48. | | |
