15 members (Otto Skorzeny, Jims46, Hawkman, Southerntruck, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 1 invisible),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | i am rewiring my 48 gmc...have question on directional switch...where do the black and blue wire coming out of switch hook to...i have a turn switch feed coming outof fuse box, and a turn switch hazard wire coming out of fuse box...do they hook to those wires...need help.... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to supply more info. There are dozens of brands of directional switches and no standard wire colors. I wrote a tech tip that will help you decode which wire is which on your particular switch. | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | i bought it from LMC...6 volt...part #36-4900...i have a black and blue wire coming out of turn switch going to a circle that has a LXP inside circle coming off circle on left side of it is a power source...coming out of fuse box is a purple wire for the turn signal feed..and abrown wire coming out of fuse box is a brown wire turn switch hazard... | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I bought my turn signal from obsolete chevy and directions and wiring diagrahm came inside the box. The letters inside the circle are the terminals on the turn signal flasher. There should be two different circles showing different wiring diagrahms depending on the type flasher you have.Just study the diagrahm and use wire nuts until you get it right. When it's right them crimp or solder . I had to build my harness from scratch one wire at a time.Take your time , you can do it. | | |
