1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | Hi. I would like to find drawings/dimensions so I can build a set of 67-72 style trailing arms for my '57 3600. Cost of aftermarket is out of reach. Thanks. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Is there some compelling reason to totally re-engineer the truck? The original type leaf spring suspension worked pretty well for decades- - - -why convert to trailing arms and coil springs? Jerry
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've seen many of the low rider trucks with the trailing arm rear suspension. I think they can get the truck lower and still have some suspension travel. | | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | In order to match the front suspension which is being converted to independent suspension with a clip from a 1983 3/4tn. and using air bags instead of coils, I would like to use trailing arms and airbags in the rear. I drive a Kenworth with airbags on the rear ends, on the cab, and the seat. The ride is unbelievable! | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I can't offer much advice on that kind of butcher job. Good luck! Jerry
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I don't know of any drawings, either. Maybe you could buy a wrecked 67-72 truck to use as a donor. Methinks you're in uncharted territory, so be sure and document and photograph it a lot to share. I'll be interested to see how this turns out.
regards, Leon | | |
