6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
#844149 04/16/2012 2:55 AM
0
0 Offline
How can anyone screw something up that is so simple...Someone who had my truck before me,(I guess)blew a water pump, the fan hit the radiator, by miracle it doesn't leak.(fairly new radiator, but its junk now) Here's how they fixed it...They took a used water pump & pulley from a 72 Nova, (as marked by yellow marker on pulley.) They cut the alternator bracket & drilled a new hole in it, so that it could be moved forward. The water pump pulley is misaligned from the crank pulley..so the fan belt is at an angle, & the fan is too close to the radiator...Now I have to undo this mess...My question..besides needing a new alternator bracket & water pump... will I need a new water pump pulley? - I'm guessing the Nova had a 230/250 ?? - If so does anyone make an aftermarket ? Thanks
Call around to some junkyards, someone should have an old 292-powered truck.
1954 GMC De Luxe COE
0
0 Offline
Thanks for the tip...all the yards in my area have late model...no more good ol boys...would rather buy from a hobbyist....
