| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | How can anyone screw something up that is so simple...Someone who had my truck before me,(I guess)blew a water pump, the fan hit the radiator, by miracle it doesn't leak.(fairly new radiator, but its junk now) Here's how they fixed it...They took a used water pump & pulley from a 72 Nova, (as marked by yellow marker on pulley.) They cut the alternator bracket & drilled a new hole in it, so that it could be moved forward. The water pump pulley is misaligned from the crank pulley..so the fan belt is at an angle, & the fan is too close to the radiator...Now I have to undo this mess...My question..besides needing a new alternator bracket & water pump... will I need a new water pump pulley? - I'm guessing the Nova had a 230/250 ?? - If so does anyone make an aftermarket ? Thanks | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Call around to some junkyards, someone should have an old 292-powered truck. | | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | Thanks for the tip...all the yards in my area have late model...no more good ol boys...would rather buy from a hobbyist.... | | |
