1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#844058 04/15/2012 9:52 PM
Hi. I would like to find drawings/dimensions so I can build a set of 67-72 style trailing arms for my '57 3600. Cost of aftermarket is out of reach. Thanks.
H Online: Content
Is there some compelling reason to totally re-engineer the truck? The original type leaf spring suspension worked pretty well for decades- - - -why convert to trailing arms and coil springs?
I've seen many of the low rider trucks with the trailing arm rear suspension. I think they can get the truck lower and still have some suspension travel.
In order to match the front suspension which is being converted to independent suspension with a clip from a 1983 3/4tn. and using air bags instead of coils, I would like to use trailing arms and airbags in the rear. I drive a Kenworth with airbags on the rear ends, on the cab, and the seat. The ride is unbelievable!
H Online: Content
I can't offer much advice on that kind of butcher job. Good luck!
I don't know of any drawings, either. Maybe you could buy a wrecked 67-72 truck to use as a donor. Methinks you're in uncharted territory, so be sure and document and photograph it a lot to share. I'll be interested to see how this turns out.
regards,
Leon
