3 members (baldeagle, Lightholder's Dad, 1 invisible), 80 guests, and 4 robots.
Topics128,018
Posts1,055,340
Members48,419
#843994 04/15/2012 5:08 PM
Should there be continuity between the power wire and the mounting base? I am trying to mount clearance lights and I get a reading between the supply wire and the mounting base. Wouldn't that mean a short in the light fixture?
Ben
You're getting a circuit through the bulb filament to ground. The only way to get a completely open circuit would be to remove the bulb from the socket.
Thanks Jerry
