2 members (1955 1 Series, baldeagle), 67 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#843994 04/15/2012 5:08 PM
Should there be continuity between the power wire and the mounting base? I am trying to mount clearance lights and I get a reading between the supply wire and the mounting base. Wouldn't that mean a short in the light fixture?
Ben
You're getting a circuit through the bulb filament to ground. The only way to get a completely open circuit would be to remove the bulb from the socket.
Thanks Jerry
