3 members (Naturalthud, Southerntruck, Peggy M), 285 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
I have the Offenhauser, am considering the headers, I have heard the Offy needs some modification to work with the Fentons, what needs to be changed, exactly?
1945 1.5-Ton Chevy Big Bolt
Maynard
More pix of the old truck
The mounting flanges are different thickness. Just use a file to get them the same. Also when you put them on the engine you will need to grind a little off the bottom of the intake manifold. Mr. Offenhauser and Mr. Fenton probably didn't speak to one another very often.
There is enough alum. there to grind, just take a little off at a time.
Tommy
59 apache 1/2t
261 short stepside
I had to grind on the mounting flanges, but not on the bottom of the intake. You'll need to do a dry fit to see where you'll need to grind. I would advise eliminating the bolts and use studs instead. Also, take the 2 alignment dowells at the ends of the heads out and replace them with studs as well. That will hepl with aligning the exhaust and gets a bit more clamping force on them as well. You may also consider eliminating the factory mounting clamps, as they do not work very well with this mainifold combintions. I ended up making my own from 1/4" stainless after fighting leaks. I'll try to get some good pix of my setup posted tomorrow.
Bill Burmeister
When I had this set up on my 1 ton, I had to grind the flanges, and a little off the intake. I used my secret weapon, the 4" angle grinder. For the aluminum, I just used an fibre sanding disk on the grinder. I had expected more drama, but it was an easy process. The worst part, was trying to hold everything up at once, and putting the bolts in. I never thought of using studs, as Bill suggested above. That's a good idea!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
ODSS President
ODSS President
Same here, the grinding. Mr. Fenton didn't get along or speak to Mr. Edelbrock either. Thank goodness there was a lot of meat so that they could clear eachother.
Edelbrock/Fenton 1
Edelbrock/Fenton 2
~ Cosmo
1949 Chevy Half Ton
Clamp the two manifolds together before attempting to install them. This should be a lot easier.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
