5 members (Gdads51, joe apple, Otto Skorzeny, 1955 1 Series, Rexville48), 128 guests, and 1 robot.
Topics128,070
Posts1,055,896
Members48,428
#843780 04/14/2012 3:10 PM
What if anything do I need to change for a 230 to 400 swap I'm thinking just motor mounts thanks
Before you start, I suggest having a plan for --
* cooling
* fuel lines
* throttle linkage
* exhaust
* alternator wiring
* clutch linkage
Compare the two engine's needs and determine whether or not the existing parts can be reused. If not, accumulate the necessary items into a kit that has everything there. Otherwise, you'll discover that something won't work during the swap, and it will be 7PM Sunday night. That will delay you by a week or more.
Guess how I know this.
regards,
Leon
Leon #844068 04/15/2012 10:21 PM
You may want to consider the engine weight and it's effect on the front suspension also. It's a good bet the springs are different.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
